Hello,I found the control xamPivotGrid for WPF. Is there a pivot grid also for window forms?I didn't find any control.
If there is no pivot grid also for window forms; can I use xamPivotGrid in a window form?Is there any code-example?
Alexander
Hi Alexander,
There is no PivotGrid in NetAdvantage for Windows Forms. I'm not sure if you can use a xam control in WinForms. I think if you post in the WPF forums, you can get a definitive answer, though.
