I have an issue now, only with infragistics controls. I open a designer and drag a UltraGrid (or any Infragitics control) to the designer surface and the control is not added to the designer, instead it adds it as a non UI component in the tray below the designer.
This issue means I can no long use any controls.....HELP!!!
-Joe
That worked. Caution should be taken to only remove the Infragistics entries in the .lic files. I removed Atalasoft entries and it blew up. Undid checkout, only removed Infragistics and all is well. Oh course in my solution I have 10 or so projects that rely on each other so all had to be touched.
Thanks,-Joe
Follow these steps to fix the problem:
1) Close all the open forms.
2) In the Solution Explorer, expand "My Project" (assuming you're using VB).
3) Double-click on licenses.licx so it opens for editing.
4) Remove all text from this file, then click File > Save All.
5) Rebuild your solution.
Everything should be fine after that. What happened was some assembly references got crossed with previous versions during the solution upgrade.
