Is it possible to set the day header text in the UltraDayView.
When set to ViewStyle = VisualStudio2005 I see this:
When set to ViewStyle = Office2007 I see this:
I would prefer the text from the 2005 style but the style of the 2007.
HiMaybe you could change property : DayTextFormat = "dddd, MMMM dd"Please let me know if you have any other questions.Regards
Actually I want to format the way the date is displayed in the header for example,
Friday, August 12
vs. the way that Office 2007 Style set it,
12 Fri
Hello Elfmanne,
Unfortunately I`m not able to take a look at the attached images, but If I understood well your scenario, you would like to use AppStyle Office 2007 with a small modification only for the day header text. If so you could modify your AppStyle with the following steps:
1. Run the AppStyle
2. Select Tab “Schedule”
3. Select intern tab “Day/Week Views”
4. Change desire properties for Normal, Selected, Hot track and so on..
Please if you have any questions, do not hesitate to ask me
Regards
