I need to produce a winchart where the angles represented by the lines in the chart are significant. Hence I need the visual distance in X/Y to be the same on the axes though the min/max may be different.
How do I control this? - am i even using the best control?
thx
l
or alternatively, the physical dimensions of the first/primary quadrant of the plot?
ie, as this is dependent on the size of the available container, and leads to the values used as the axis/marker scales, can also help me to figure out the AR.
Then can you tell me how/where to find the units between each tick mark along an axis? - if the axis is being scaled automatically, this value will be changing and i want to find out what it is?
tia
l.
Hello luminary,
As far as I know our UltraChart doesn`t have such kind of functionality. The angles depends of the points (the values on X and Y axis for each point), and also the distance between two points of X axis and distance between two points of Y axis. Please let me know if you have any questions.
Regards
So the demo you provided has the same problem that I am facing. If the graph/window/form is resized, the angles change as the axes limits are fixed - and so the graph is scaled to fit within the physical size limits.
How does one control the graph so that angles are invariant?
Thx for the zip. I'll take a look. Just to clarify what I am trying to do - a line between (0,0)-(1,1) needs to appear on a 45 degree angle. I find that if the axes scale, shape of the chart object - which is resizable impact the on screen angle. I need the angle of this line to always be 45 deg.
Thxl.
