Dear all,
I have one ultraExpandableGroupBox with header text. I want to set the font on it when program run.
But I find that it cannot be set. Is it possible??? Any similar problem that you know??
if (ctl is Infragistics.Win.Misc.UltraExpandableGroupBox) ((Infragistics.Win.Misc.UltraExpandableGroupBox)ctl).HeaderAppearance.FontData.Name = StoreServer.VO.Common.PropertiesVO.GridFont.Name;
Are you loading an Application Style Library (*.isl) file into your application? If so, the isl will override the program settings. Look for a call to StyleManager.Load in your code.
Hello Rchiu5hk,
I try to reproduce your issue in a small sample, but without success. Could you please take a look at the attached sample and if you think that I didn’t reproduce your scenario, feel free to modify my sample and revert it back to me. I`ll be glad to research it. In the sample I set properties below at run time:
- ultraExpandableGroupBox1.HeaderAppearance.FontData.SizeInPoints = 20;
- ultraExpandableGroupBox1.HeaderAppearance.FontData.Name = "Arial Narrow";
Please if you have any questions, do not hesitate to ask me
Regards
Georgi
