2114
EmbeddableEditor for the Grid cell
Please Help! To be simple this is my problem:
I have a class MyScore that "accepts" any string that "X:Y" represents, and converts it in the correct "X:Y" format. Say strings like "5:2", "0:0", "9:14" etc are accepted, and transformed in "X:Y"(where X and Y are any natural number), any other string is rejected, like "b:7" or "+9"
Now, I have a ScoreTextBox, that uses the MyScore class constructor that leaves the user to enter only valid scores, by default leaving "_:_" format.
So. Actually, I need to have exactly the same behavior like does my ScoreTextBox. Exactly the same. Is not desirable to rewrite or duplicate the existing ScoreTextBox code.
Now, I thought that putting myScoreTextBox instance as EditorControl to a cell will be sufficient. But I discovered that I need to implement on ScoretextBox a IProvidesEmbeddableEditor, so have an EmbeddableEditorBase.
Please help. I use the Score(string) constructor to determinate if the text is valid or not (in case of exception I invalidate the text to default one)
How can I implement Editor for this textBox, need I to do that?
