1705
What's the best way to make rows bold/not bold at runtime?
Depending on the data, some rows need to be bold and some not bold.  Right now I'm using:
e.Row.CellAppearance.FontData.Bold = Infragistics.Win.DefaultableBoolean.True;
 to make a row bold.  But the problem is, the rows that AREN'T bold then have a little icon of a pen in the RowHeader area, as if someone is editing them.  How can I avoid this pen stuff?
  • 469350
    If you are seeing a pencil icon on a row, then something is editing the data in that row. There is no reason why setting the Font to bold should have any effect on this.
    My guess is that you have an unbound column in your grid and you are populating the values of the cells in tis column in code. What you should do in a case like this is call Update on the row after you make the changes. This commits the changes to the row so it no longer has pending changes.
  • 918
    This has been discussed so many times there really needs to be a grid.appearance item to disable it.  I have a remove pencil class that uses a draw filter to remove (or add whatever) to the row header.  To use it just declare the class  dim rp=new clsremovepencil then put this line in the form load event:  mygridname.DrawFilter = rp.
    I actually think one of the ingragistics guys posted this a couple or more years ago. It didn't work exactly the way I needed so I commented a bit of stuff out. As is it removes the pencil all the time.  I think it might have been written to remove the pencil part of the time.  Good luck
    Imports Infragistics.Win
    Imports Infragistics.Win.UltraWinGrid
    Public Class clsRemovePencilImplements IUIElementDrawFilter
    Public Function GetPhasesToFilter(ByRef drawParams As _
    Infragistics.Win.UIElementDrawParams) As Infragistics.Win.DrawPhase _
    Implements Infragistics.Win.IUIElementDrawFilter.GetPhasesToFilter
    ' Drawing RowSelector Call DrawElement Before the Image is Drawn
    If TypeOf drawParams.Element Is _
    Infragistics.Win.UltraWinGrid.RowSelectorUIElement Then
    Return DrawPhase.BeforeDrawImage
    Else
    Return DrawPhase.None
    End If
    End Function
    Public Function DrawElement(ByVal drawPhase As _
    Infragistics.Win.DrawPhase, ByRef drawParams As _
    Infragistics.Win.UIElementDrawParams) As Boolean Implements _
    Infragistics.Win.IUIElementDrawFilter.DrawElement
    ' If the image isn't drawn yet, and the UIElement is a RowSelector
    If drawPhase = drawPhase.BeforeDrawImage And TypeOf _
    ' Get a handle of the row that is being drawn
    Dim row As UltraGridRow = _
    CType(drawParams.Element.GetContext(Type.GetType("UltraGridRow")), _
    UltraGridRow)
    ' If the row being draw is the active row
    If row.IsActiveRow Then
    ' Draw an arrow
    drawParams.DrawArrowIndicator(ScrollButton.Right, _
    drawParams.Element.Rect, _
    UIElementButtonState.Indeterminate)
    ' Return true, to stop any other image from being drawn
    Return True
    End If
    End If
    ' Else return false, to draw as normal or true to stop pencil
    'Return False
    Return True
    End Function
    End Class
