445
Changing expanded row appereance (dont change your x-Position please :( )
Hiya team-Infragistics.
I recently started programming a lil something with your UltraWinGrid.
Basicly the Grids DataSource is filled with a List (Of ...)
The Item in the list can have a new List(Of ...) attached and so on.
This leads to rows I can expand and collapse.
Right now the Grid will shift every expanded row about 16Pixel to the right from its original row.
Is there any way to avoid changing the x-Position of the expanded row?
Here is a screen of what I get right now:
and here is what I'd like to achieve:
I hope you'll understand what I mean. I'll try to explain better if needed. Thx in advance.
  • 469350
    This should do it:
            private void ultraGrid1_InitializeLayout(object sender, InitializeLayoutEventArgs e)
                UltraGridLayout layout = e.Layout;
                foreach (UltraGridBand band in layout.Bands)
                    if (band.Index > 0)
                        band.Indentation = 0;
