2715
WinGrid BeforeCellUpdate problem
Hi!
I'm trying to implement the following behaviour. I have an editable grid - if the user changes a value i want to show him a warning with the posibility of accepting or canceling that change. This is how i implemnted it :
void grid_BeforeCellUpdate(object sender, BeforeCellUpdateEventArgs e) {
            if (grid.ActiveCell.Column.Key == "COL") {
                try {
                    MessageBoxButtons btns = MessageBoxButtons.YesNo;
                    if (MessageBox.Show("If you change this all child values will be erased automatically. Are you sure you want to do this ? ", "Warning", btns) == System.Windows.Forms.DialogResult.No) {
                        e.Cancel = true;
                    else {
                        UpdatedContractRows.Add(e.Cell.Row);
                catch (Exception ex) {
                    MessageBox.Show(ex.Message);
                    e.Cancel = true;
The problem is the following - if i click yes, the value is commited and it changes in the cell's value - as it should be. But, if i click No, the message box appears again and i have to click No again. only after that it cancels the event and the cell returns to the initial value.
Any ideea how can i fix this ?
Thank you!
