220
CheckBox in WinTreeColumn?
it's possible to create a winTreeColumn as CheckBox programmatically?
With Code such like
        private UltraTreeNodeColumn checkBoxColumn()
            UltraTreeNodeColumn checkboxColumn = new UltraTreeNodeColumn();
            checkboxColumn.DataType = typeof(bool);
            checkboxColumn.CellAppearance (??????)
            return checkboxColumn;
Thanks and Greatings: Rudy
  • 220
    i found out that it's simple with the AllowCellEdit - Option. Now I set it to "AllowCellEdit.Full", but I'm not able to edit the cell.(?)
    The Background:
    The Data comes by using the following code:
    UltraTreeNode nodeWP = this.ultraTreeRequirements.Nodes.Add("Root"); nodeWP.Nodes.SetDataBinding(eCU_ArticleQuery.Execute(MergeOption.AppendOnly).ToList(), "");
    In next step i Neet an unbound Checkbox to sho some dependencys:
    private void ultraTreeRequirements_ColumnSetGenerated(object sender, ColumnSetGeneratedEventArgs e)
                switch (e.ColumnSet.Key)
                    case "List1":
                        e.ColumnSet.Columns["ID"].Visible = false;
                        e.ColumnSet.Columns.Add("Check").DataType = typeof(bool);
                        e.ColumnSet.Columns["Check"].AllowCellEdit = AllowCellEdit.Full;
                        break;
                    case "":
                    case "LIst2":
                        e.ColumnSet.Columns["Value"].Visible = false;
                        break;
    What's to do to edit the manually added cell?
    Thanks an Greatings: Rudy
