705
When I update the value of a cell in a ultragrid does the datasource get updated
I set the datasource of an ultragrid to a datatable.  When I update a cell of the ultragrid like ultraGrid1.Cells[0].Value = "test",  then I cast the datasource from the Ultragrid the datatable does not contain the value I just assigned.
  • 69832
    Suggested Answer
    The UpdateMode property determines when the value is committed to the data source. By default the value is not committed until the user leaves the row on which the change was made. You can cause an immediate update by calling the Update method.
