700
default size for columns
this should be a simple thing,
i am trying to set a default width on a column (this would mean if a cell has more content then the width, it should be hidden), and let the user resize as they please.
but it seems that the column will be auto re-sized to fit the content. the only way i've been able to set the default is by setting min and max width to the same size, but this leaves the column not resizable.
what is the property that will let me set default width, and not have it resize to fit the contents?
