100
Win Grid - limit cell length input
Good afternoon.
Is there a way to limit cell input (length). I would like to limit the length of the cell input based on a drop-down column. For example: if "R" chosen then another cell in the row would be limited to 3 in length. If "T" is chosen then the cell length would become 15. I see you can limit the "column" but I am looking to limit the cell in each row based on the drop-down. In the end, the designated cell in each row might have a different length (3 or 15) dependent upon what was chosen. Thank you for your help.
  • 5520
    Suggested Answer
      private void ultraGrid1_BeforeCellActivate(object sender, Infragistics.Win.UltraWinGrid.CancelableCellEventArgs e)
                if (e.Cell.Column.Key == "ColumnKey")
                    if (e.Cell.Row.Cells[0].Value.ToString() == "R")
                        e.Cell.Column.MaxLength = 3;
                    else
                        e.Cell.Column.MaxLength = 15;
