385
Disable dropdown button
How to disable the dropdown button in ultrawindgrid.dropdown to be seem Autocomplete TextBox?
Plz ref the below image.
which of the code part do i need to change-
With UltraGrid1.DisplayLayout.Bands(0)
 .Columns.Item("CNTR").Style = UltraWinGrid.ColumnStyle.DropDown
 .Columns.Item("CNTR").AutoCompleteMode = AutoCompleteMode.SuggestAppend
 .Columns.Item("SealNo").Style = UltraWinGrid.ColumnStyle.Edit
End With
  • 469350
    Verified Answer
    You cannot remove the button using the properties of the grid alone, you have to use an editor.So you don't need to set the column's Style, the editor will take care of that.
                '.Columns.Item("CNTR").Style = UltraWinGrid.ColumnStyle.DropDown
                Dim editorWithCombo As New EditorWithCombo
                editorWithCombo.ButtonDisplayStyle = Infragistics.Win.ButtonDisplayStyle.Never
                .Columns.Item("CNTR").Editor = editorWithCombo
            End With
