I have a problem in visualizing dependencies with WingattView. In my application I added a feature that allows to hide non working hours through a checkbox: if the checkbox is not checked, I hide non-working hours using this code: (note: uci1 is the UltraCalendarInfo that is bound to the UltraWinGattView control)
Private Sub chkShowNonWorkingHours_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles chkShowNonWorkingHours.CheckedChanged If sender.checked Then Me.uci1.LogicalDayOffset = Nothing Me.uci1.LogicalDayDuration = New TimeSpan(24, 0, 0) Else Dim hours As Int32 = Int32.Parse(7) Dim minutes As Int32 = Int32.Parse(0) Dim logicalDayOffset As TimeSpan = TimeSpan.FromMinutes((hours * 60) + minutes) Me.uci1.LogicalDayOffset = logicalDayOffset Dim hoursd As Int32 = Int32.Parse(12) Dim minutesd As Int32 = Int32.Parse(0) Dim logicalDayDuration As TimeSpan = TimeSpan.FromMinutes((hoursd * 60) + minutesd) Me.uci1.LogicalDayDuration = logicalDayDuration End If End Sub
this works fine, but if I have some dependencies when I move along the timeline in the chart I see the lines disappearing or worst I see a straight line (as if the two tasks I'm relating are outside the timeslot I'm visualizing, one in the past and one in the future). This problem disappear if non-working hours are shown....
Can anyone help me?
I try to reproduce your scenario and issue in a small sample using the provide code, but wihtout success. If you are able to upload small sample with your scenario, I`ll be glad to research it for you
Regards
I'm getting the same problem, is it possible to have a reply?
