40
Tooltip placement issue in UltraChart
I have a issue to do with the tooltip being misalligned when the tabs are pinned.  Below is a screenshot. If only the right panel is pinned, the tooltip is aligned just fine. However, when the left panel is pinned the tooltip gets 'shifted' to the left. The ultrachart being used is anchored to the top and left. For the ultrachart, i tried setting none for the anchor and the tooltip was aligned fine even with the left panel pinned, however this would leave the ultrachart in a floating position. I also tried setting the anchor to all sides but the tooltip would get misaligned. It seems whenever the ultrachart is achored to the left, the tooltip would get shifted to the left.
Any thoughts on what else I could try? I currently using infragistics version 10.3, I have also tried version 11.1
