133
Panel not letting window resize?
I am facing an issue, whether the application window cannot be properly re-sized because of (I think) the splitter.
The main window of the application has a number of controls with control1 having a horizontal splitter at the bottom of it. If I attempt to resize the window, I can only resize it upward until the bottom edge of the window hits the bottom edge of control1 and the its bottom splitter(which is now covered by the bottom panel of the window). So in order to resize the window height, I have to drag the bottom edge of the window up, until the above happens, release mouse click and then repeat that a number of times to resize the window as required.
I got the control1 and all its parent controls (except the main window) to be dynamically resized on main window's sizeChanged even and the do resize visually, yet the window cannot be properly resized.
So once again, to reiterate - the bottom edge can be moved up until it hits the splitter (which is at the bottom of Control1) and no further. To move it further, the I have to release left mouse button of the edge of the window, click again, drag up the same amount, repeat...
I hope I'm making myself clear ^^
Thanks!
mockMainApplication.zip
