80
can't reach controls in winTab
 Hi Folks,
I have form that contains many containers. And in my code I look for every container and set enabled property for each child control to false. The code works with any container control except winTab.
Please any idea.
Public
Class Form2
Private Sub LockTheControls(ByVal ctl As Control, ByVal Lock As Boolean)
Dim ctlChild As Control
For Each ctlChild In ctl.Controls
If (TypeOf ctlChild Is UltraDropDownButton) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraButton) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraCombo) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraCalculator) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraCalculatorDropDown) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraCheckEditor) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraColorPicker) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraComboEditor) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraCurrencyEditor) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraDateTimeEditor) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraFontNameEditor) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraNumericEditor) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraOptionSet) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraPictureBox) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraTextEditor) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraTimeZoneEditor) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraTrackBar) Then ctlChild.Enabled = Lock
If (TypeOf ctlChild Is UltraFormattedTextEditor) Then ctlChild.Enabled = Lock
Next
End Sub
Private Sub TraverseForm()
Dim ctl As Control
For Each ctl In Me.Controls
If IsContainerControl(ctl) Then
If ctl.HasChildren = True Then LockTheControls(ctl, False)
Else
LockTheControls(Me, False)
End If
Next
End Sub
Public Function IsContainerControl(ByVal ctlControl As Control) As Boolean
Dim bResult As Boolean = False
Dim objControlType As Type
Dim objDesignerType As Type
Dim objAttribute As AttributeDim objDesignerAttribute As System.ComponentModel.DesignerAttribute
objControlType = ctlControl.GetType
For Each objAttribute In objControlType.GetCustomAttributes( _
GetType(System.ComponentModel.DesignerAttribute), False)
If TypeOf objAttribute Is System.ComponentModel.DesignerAttribute Then
objDesignerAttribute = CType(objAttribute, System.ComponentModel.DesignerAttribute)
objDesignerType = System.Type.GetType(objDesignerAttribute.DesignerTypeName)
If GetType(System.Windows.Forms.Design.ParentControlDesigner).IsAssignableFrom(objDesignerType) Then
bResult = True
Exit For
End If
End If
Next
Return bResult
End Function
Private Sub Form2_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
TraverseForm()
End Sub
End Class
  • 44743
    Verified Answer
    This is due to the fact that the UltraTabControl also contains other containers. You should recursively call your LockTheControls method when you encounter an UltraTabPageControl within LockTheControls. This should set the correct enabled state of all child controls in the tab control.
