I'm using an UltraGrid containing a column with a boolean value. I want to change the style of the checkbox displayed in this column. I defined this style in an isl file designed using AppStylist application.
This works fine except if I want to change the checkBoxGlyphInfo property of the checkbox. Then nothing is changed in my grid. I tried to place a checkbox outside of my grid and then the style I defined with the checkBoxGlyphInfo property is applied to this checkbox.
Am I doing something wrong?
I am submitting this as a development issue. You will receive more information through the support case.
Thanks Chris. It works.
Thank you for the sample. For some reason, toggling the HeaderCheckBoxVisibility worked in my sample but not in yours. I apologize for that. Instead, toggle the HeaderCheckBoxSynchronization property between None and Default. This definitely will trigger the synchronization process, and it makes more sense to use that property anyways. I verified this workaround in the sample you provided, and it updated the HeaderCheckBox state successfully.
Let me know if I can be of further assistance.
Chris.
Are you sure this workaround (using HeaderCheckBoxVisibility) works? I tried it in my application and in a prototype and the header checkbox is not upated.
I attached the prototype to this message.
It doesn't look like there is a workaround for the HeaderCheckBox - Glyph issue at this time.
In regards to your final issue, I took a brief look at the involved code. It appears the synchronization is not triggered when you refresh the Rows. This should also be put into developer review.
As a workaround, toggling the visible state of the checkboxes (using HeaderCheckBoxVisibility) should dirty the cached values, triggering the synchronization process. If you wrap this between SuspendLayout()/ResumeLayout() calls, you can minimize any flickering of the checkbox.
Hopefully this helps.
Chris
