How I can change the UltraCombo filter type.
I would like the same filter type of my UltraWinGrid.
On UltraCombo filter I can't typing below the header column for filter my data.
Thank you.
The FilterRow is not supported for UltraCombo. UltraCombo only supports filtering using the column header icons.
You should Submit a feature request to Infragistics
