690
CellChange event
I have several cases where I'm using the CellChange event to react to changes in a grid, which usually involves updating another column in the grid. The problem I'm having is that if the user changes back to the original contents of the cell without leaving the cell (either by hitting the Esc key or reentering the original contents) the event doesn't fire and the other columns no longer show the correct information.
The workaround seems to be to use the KeyUp event, along with using the Cell.EditorResolved property to read the correct text out of the cell. It seems to be working, but I think it's a lot of effort to handle a fairly common scenario. I'm wondering if this is the intended behavior and if there's an easier way to do this.
Parents Reply Children
No Data
