520
Key already exists error in UltraWinTree
I need to represent the following hierarchy in a tree control:
10001
    +--10001-01
    |      +-- A
    |      +-- B
    +--10001-02
           +-- A
           +-- C
Here is my code, which gives me the dup key error on adding the 10001-02->A node:
            UltraTreeNode node = null, childNode = null;
            foreach (DataRow row in dt.Rows)
                curAccount = (string)row["AccountCode"];
                curSubAccount = (string)row["SubAccountCode"];
                curFund = (string)row["FundShortName"];
                int accountId = (int)row["AccountId"];
                int subAccountId = (int)row["SubAccountId"];
                int fundId = (int)row["FundId"];
                if (curAccount != prevAccount)
                    Trace.WriteLine("Added node " + curAccount);
                    node = tvInvestor.Nodes.Add(curAccount);
                else
                    node = tvInvestor.Nodes[curAccount];
                if (curSubAccount != prevSubAccount)
                    Trace.WriteLine("Added child node " + curSubAccount);
                    childNode = node.Nodes.Add(curSubAccount);
                    Trace.WriteLine("Child node children count = " + childNode.Nodes.Count);
                else
                    childNode = node.Nodes[curSubAccount];
                Trace.WriteLine("Adding grandchild node " + curFund);
                childNode.Nodes.Add(curFund); -- > Error on this line
                prevAccount = (string)row["AccountCode"];
                prevSubAccount = (string)row["SubAccountCode"];
What am I doing wrong?
