930
Lock the dial in a radial gauge
Is there a way to lock the dial? Currently a user can manually move the dial.
Ryan
  • 53790
    Suggested Answer
    Hello Ryan
    Maybe one possible approach to achieve the desired behavior is to set property :
    ultraGauge1.Enabled = false;
    By this way the users could not be able to change manualy the dial value, but you will be able to modify the value through the code. For example:
    private void ultraButton1_Click(object sender, EventArgs e)
        RadialGauge ss = ultraGauge1.Gauges[0] as RadialGauge;
        ss.Scales[0].Markers[0].Value = (double)ss.Scales[0].Markers[0].Value + 10;
    Regards
