Hi, I can't figure out how to delete all subtask for task, and save it to database. I made this recursive function, which delete tasks from gantview, but allways throws exception when saving to database
private void deleteTasksAndSubtasks(Task task) { if (task.Tasks.Count > 0) { for (int i = 0; i < task.Tasks.Count; i++) { Task taskF = task.Tasks[i]; if (taskF.IsSummary == true) { for (int j = 0; j < taskF.Tasks.Count; j++) this.deleteTasksAndSubtasks(taskF.Tasks[j]); task.Tasks.Remove(taskF); } else { task.Tasks.Remove(taskF); } } } }
And I call this function like this
private void ultraGanttView1_TaskDeleting(object sender, TaskDeletingEventArgs e) { if (e.Task.IsSummary) { deleteTasksAndSubtasks(e.Task); saveTasks(); } }
It can delete task and his subtask, but if subtask has its subtask, ie if it has more than 2 levels, it always throws exception. What could be the problem ?
And I have another question. When I right click on ganttview and in toolstrip click on "Add task below selected task" in database it saves changes, but it doesn't write Project Key for this subtask I created. So next time i reload project, task is not in list, but its in database. and Project Key value is null. I tried to set Project Key value in ultraGanttView1_TaskAdded function, like this
e.Task.Project = ultraCalendarInfo6.Projects[1];
but it doesn't write project key to database. Any solution for this ?
I suppose that this forum thread is duplication with : http://ko.infragistics.com/community/forums/t/60736.aspx Please take a look there for more details.
I made some changes in upper function.
private void deleteTasksAndSubtasks(Task task) { bool deleted = false; for (int i = task.Tasks.Count; i > 0; i--) { Task taskF = task.Tasks[i - 1]; if (taskF.IsSummary == true) { deleteTasksAndSubtasks(taskF); deleted = false; } else { task.Tasks.Remove(taskF); deleted = true; } if (deleted == false) { task.Tasks.Remove(taskF); } } }
and it deletes everything except the root task, which I click on, and one of its children. If I use message boxes everytime I remove Task, I see that all tasks are deleted, but not in the database. Still no luck, but I am closer.
