115
EditorWithCombo ValueList not populating
I'm trying to set the editor for all the cells in the 1st row of my grid (which happens to be fixed).  I think I'm doing this right, but for some reason I can't get the settings to pass up the valuelist to the editor...
    Private Sub grdDatasource_InitializeRow(sender As Object, e As Infragistics.Win.UltraWinGrid.InitializeRowEventArgs) Handles grdDatasource.InitializeRow
        If grdDatasource.Rows.FixedRows.Contains(e.Row) Then
            Dim theSettings As New DefaultEditorOwnerSettings
            Dim MyDropdownList As New UltraDropDown
            Dim tblList As New DataTable
            tblList.Columns.Add("ColName")
            tblList.Rows.Add("col1")
            tblList.Rows.Add("col2")
            MyDropdownList.SetDataBinding(tblList, "ColName")
            MyDropdownList.ValueMember = "ColName"
            MyDropdownList.DisplayMember = "ColName"
            theSettings.ValueList = MyDropdownList
            For Each CurrentCell As Infragistics.Win.UltraWinGrid.UltraGridCell In e.Row.Cells
                Dim mySettings As New DefaultEditorOwnerSettings()
                mySettings.ValueList = MyDropdownList
                Dim myEditor As New EditorWithCombo(New DefaultEditorOwner(mySettings))
                CurrentCell.Editor = myEditor
            Next
        End If
    End Sub
mySettings.Valuelist appears to have the proper list bound to the table, but once I create the meEditor object, passing in the mySettings, the valuelist becomes NOTHING.
Any idea why the Editor isn't picking up the Valuelist from the settings object?
