We want the ultraformattedprogressbar in such a way that it should show 2 percentage values - (i) One for the Limit (ii) second one for actual value.
Also, e.g if the limit is 50 and actual value is 80, then the progressbar should be colored in following format-
0-40 in orange color
40-60 in yellow color
60-80 in green color.
Rest space will be white.
Similarly if Limit is 50 and actual value is 10, then 0-10 should be colored in red.
Can we do such thing with UltraProgressBar? Please reply.
Shraddha
Hello Shraddha,
You could take a look at the following forum threads, which also correspond to your question:
http://community.infragistics.com/forums/t/37086.aspx
http://forums.infragistics.com/forums/t/28511.aspx
Please feel free to let me know if I misunderstood you or if you have any other questions.
