Dear all,
Is there any better method to insert the total row which will be updated.
Thank you for contacting me.
Yes, the total value will get updated.
Please do not hesitate to ask if something comes up.
Would the total value get updated when there is any values changed from 0 to ##.## ??
Hello rchiu5hk,
I think that you could take a look at 'Summary Rows'. The following links could be helpful for you: http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=6144 and http://community.infragistics.com/forums/t/20129.aspx.
You could also review our sample called :"V2 Summary Rows".
This sample could be located in our 'Windows Forms Feature Browser'. If you have this installed(if you have marked 'Samples' when installing Net Advantage), you could run it from 'Start Menu' -> 'All Programs' -> 'Infragistics' -> 'Windows Forms' -> 'Samples' -> 'Samples (local)'. When it loads, please navigate to the 'Grids' tab and then 'Launch' the 'Samples Explorer'. Or you could type in the 'Search:' "Samples Explorer". Then please select the 'V2 Summary Rows' sample and click on the 'Launch Sample' button in order to review the application.
Please feel free to let me know if I misunderstood you or if you have any other questions.
