Is there a recommended schema for full scheduling support. I am starting with a clean sql server 2008 db.
I have installed the demo and found the following sql file:
My Documents\Infragistics\NetAdvantage 2011.1\Windows Forms\Samples\WinSchedule\CS\WINSCHEDULE DATABASE DEMO CS
-Markus
There is no schema per se but that sample includes a SQL script from which you can get the data types of each field.
