35
Confused [*-)]
Confused while trying infragistics first time m tottaly confused help files not working for me till now i culdt even got mine first style library to load into mine vs2005 winform project.Angry
can smone please tell me a linkk to stepby step guide or
" Dummies guide for infragistics" [:'(]
  • 1265
    Loading Your AppStylist Style Library Into Your VB NET 2005 Application
    In VS 2005, right click on your application name and go to Properties:
    When the properties page loads, go to the Application Tab, then click on View Application Events:
    The ApplicationEvents.vb file will be created and opened. Go to the General dropdown, and choose (My Application Events):
    Go to the Declarations dropdown, and choose Startup:
    The Application_Startup event will be added to the code window:
    Add the line of code below, substituting your file name/path for your AppStylist style library (.isl file) where it says InsertYourFileNameHere.isl:
    Infragistics.Win.AppStyling.StyleManager.Load("InsertYourFileNameHere.isl")
    In AppStylist, make note of the style set name you would like to use. If you only made one style set in your style library, it will be called Default. Otherwise, make note of the style set name, in this case it is YourStyleSetName:
    In the properties of the control(s) you wish to apply styles to, type in the name of the style set you wish to use for that specific control:
    When you build/run your application, the specified style set in your style library will be applied to the control:
  • 28464
    Thanks for your interest in our products and for dropping us a line. There are a lot of online resources which can help you getting started. I personally use the online help system a lot, you can take a look at the following link (The Winforms Controls section)
    http://help.infragistics.com/NetAdvantage/NET/2008.1/CLR2.0/
    But what really helped me a lot were the online videos which show how you can use various Infragistics products. The videos are located here:
    http://community.infragistics.com/videos.aspx
    and I personally recommend
    Intro To Samples
    http://community.infragistics.com/videos/get-started/intro-to-samples.aspx
    Winforms Assemblies:
    http://community.infragistics.com/videos/get-started/about-winforms-assembly-refs.aspx
    And this Winforms demo (a little bit more advanced)
    http://community.infragistics.com/videos/winforms/wingrid-top-features.aspx
    Hope this helps.
