New Visual Studio 2010 WinForms C# project and imported existing form containing IG 2009 controls, which were updated to NetAdvantage 2011.
Our practice and existing code would always first our UltraCombo's datasource = null; before setting the datasource = datatable object returned from a SQL procedure call.
I was shocked to see that if the UltraCombo was already bound to a datatable, the calling of the same method to set a datasource is firing the RowSelected event of the combo when combo.datasource = null; is executed!
Needless to say, this is wreaking havoc in the project and we're looking for direction.
Is this a bug or something new in 2011??
Thanks!
Hi Michael,
Yes, sorry. I responded only to the case for this post (CAS-78720-GHHPF4). I will close this post as there are two solutions. Here is that text from the case:
I was able to quickly reproduce the issue, which turn out to be the same issue just found this morning in my other post "Unexpected behavior changes between 9.2 and 11.2?".
Michael S. In your sample, simply change Combo2's .Value member to "State". Because three of the records have "NJ" as their State, when Combo2 loses focus "Jersey City" is left in Combo2 as the selected record even if you select "Newark" or "Trenton". This is the smoking gun and does not happen for us in our current production application using 9.2. Changing the .Value and .DisplayMemeber to "City" is the equivalent of what I need to do to "fix" our upgraded 11.2 application.
The new property you mention also fixes the issue, is the better solution, and turns to fix a larger issue I was having with another UltraCombo, which I am unable to replicate using your sample.
[Michael S.] "Try setting the "ItemMatchingMode" property of ultraCombo2 to "ValueListItemMatchingMode.DoNotConvertDataValueToString"."
At this point I am good to go. Is there any documentation that can be shared regarding the new (to us / post 9.2) Combo property ItemMatchingMode?
[Michael S.] http://help.infragistics.com/NetAdvantage/WinForms/current/CLR2.0/?page=Infragistics2.Win.UltraWinGrid.v11.2~Infragistics.Win.UltraWinGrid.UltraDropDownBase~ItemMatchingMode.htmlThanks to everyone who helped me resolve this issue!
Jaime,
Did you try my suggestion?
In the sample that you are referring to try setting the "ItemMatchingMode" property of ultraCombo2 to ValueListItemMatchingMode.DoNotConvertDataValueToString
I will update the case notes with these findings. I do not know if it is appropriate to link case numbers in this forum for Mike S. to see, or would it be best for you to attach the sample from the case?
Thank you Micheal S. and Mike S.
This post was elevated to a Support Case, so I now have examples from both of you. This morning I was able to modify an example for another forum post of mine dealing with a single UltraCombo to reproduce that issue, which looks like the non-unique column I set as the Combo's .Value is causing that issue, which is not an issue with the current production application running 9.2.
I will work on one of your samples now to see if I can replicate this issue with the chained Combos.
Thanks again, Jaime
