I upgraded a project from 10.3 to 11.1 using the version utility, in my references I don't have any visible 10.3 references and all the .licx files contain references to 11.1 (I went back and deleted the contents of all 11.1); however, I get this error after deploying my application to the end user:
Could not load file or assembly 'Infragistics2.Win.UltraWinGrid.v10.3, Version=10.3.20103.2094, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
When I run the compiled version on my end, when I go to our About Box I can see that the code is still referencing the 10.3 version; even though, I upgraded the solution (and projects) to the latest release of 11.1.x.x and there are no direct references to 10.3
I ran into this same issue after upgrading from v13.2 to v16.2
The issue was some stored layouts in the .resx file that referenced the previous version. Removed them and it fixed this issue.
Is this something the update utility can handle?
The project I was working on was targeting .Net Framework 4. I upgraded the entire project to use Infragistics4.... controls. The issue has not come up.
Hello Pete,
If you have any new information about this behavior, I would be glad to take a look at it.
If you need any other assistance please do not hesitate to ask.
Thank you for letting me know.I will be waiting for your results.
I'll give it go and let you know.
