655
Edit a boolean column displays 'True' or 'False'
I fill a ULTRAGRID with data, which then I want to edit.
This grid has a column with a boolean data ("ACTIVE" column).
When I load the data, the column appears with a CHECKBOX, which is what I want.
At the time I go into edit mode, column data become text ("True" "False").
To test only create a form and add an UltraGrid and a UltraButton:
Private Sub UltraButton1_Click(sender As System.Object, e As System.EventArgs) Handles UltraButton1.Click
Dim dt As New DataTable
dt.Columns.Add("NAME", System.Type.GetType("System.String"))
dt.Columns.Add("ACTIVE", System.Type.GetType("System.Boolean"))
dt.Rows.Add("One", True)
dt.Rows.Add("Two", False)
dt.Rows.Add("Three", True)
dt.Rows.Add("Four", False)
dt.Rows.Add("Five", True)
UltraGrid1.DataSource = dt
Dim _objEdicionCheck As New Infragistics.Win.UltraWinEditors.UltraCheckEditor
_objEdicionCheck.Style = EditCheckStyle.Check
_objEdicionCheck.Visible = True
UltraGrid1.DisplayLayout.Bands(0).Columns("ACTIVE").Style = UltraWinGrid.ColumnStyle.CheckBox
Dim ucCheck As New Infragistics.Win.UltraWinEditors.UltraControlContainerEditor
Me.Controls.Add(_objEdicionCheck)
ucCheck.EditingControl = _objEdicionCheck
ucCheck.EditingControlPropertyName = "Checked"
UltraGrid1.DisplayLayout.Bands(0).Columns("ACTIVE").EditorComponent = ucCheck
End Sub
If I edit the column (by double click), the cell becomes in a checkbox.. and when I leave the cell, the columns returns to "True" or "False"
Why the column lost the style (EditCheckStyle.Check)?
