1705
Exporting Grid with child bands using the UltraGridExcelExporter
I have an ultragrid bound to a dataset directly which has a master table with 2 details tables (linked to each other with relationships).
The grid display childbands as expected, however we are having the following issue with the UltraGridExcelExporter:
When we filter our parent table from 10,000 records to 10  the excel exporter takes the same amount of time that it takes to export  the original 10K (more than 2 minutes!). The exported file eventually will have only the 10 rows but.... why is it taking so long?
Any help would be appreciated, thanks!
  • 469350
    When you export the grid, the grid clones it's DisplayLayout and all of it's rows. This is a very powerful thing, because it means that you can make changes to the export layout or the export rows without affecting the on-screen grid.
    But it also means that the the filtering and sorting has to be re-applied to the cloned rows.
    What version of the controls are you using?
