I have a ToolBar with 5 StateButtons with Icon and Caption below the text. There are some captions with 3 or 4 words and I want to split the caption in two lines. I tried to insert a carriage return and line feed (vbCrLf) between two words, but it does not works: The StateButton increase the Height but only shows the first line... There are some way to have the Captions in two lines?
Thank you
This is a bug that has already been reported and fixed in version 7.3 and later. However, I'm not sure if the hotfix was released yet. I would recommend submitting the issue to the support group and referencing issue BR29251: http://ko.infragistics.com/gethelp. If you are using 7.3 or later, you will be notified when the hotfix is released. If you are using an earlier version that is still supported, the fix will be moved back to the version you are using.
