I am using a UltraWinGrid in my project and I want to know if multi-undo and redo is supported by this control. Please advise.
Adrian
No, there's no functionality in the grid for this. You could code it yourself, of course, but the grid doesn't have this sort of undo capability built-in.
I want to be able to undo the changes of cell. I realize there is a undo cell call you can make, but it does not track all the changes to a cell throughout a entire session. For instance, I change the text 'Bill' to 'Billie' and then to 'Billy' without leaving the cell; so the changes were not committed, if I then perform an undo on this text the value of the cell is put back to 'Bill' the original value. What I would want to happen is that if I hit undo, the text is changed back to 'Billie' and if I the perform the undo action again the text then changes back to 'Bill'. It doesn't seem like the undo functionality supports this capability correct?
Hi Adrian,
It depends what you mean - what do you want to undo?
The AllowMultiCellOperation functionality has undo and redo support.
But there's nothing built into the grid to undo adding or editing of rows other than that.
