1440
ultratree cannot form a hierarchical tree view layout from a single DataTable using DataSet and DataSet Relation
It seems the ultratree cannot  form a hierarchical tree view layout from a single DataTable. I have a simple table which contains four columns and  I want to have parent child relationships between the columns. I want the first column to be the parent of the second column, the second columns to be the parent of the third column, and the third column to be the parent of the fourth column.  The DataTable was place in a DataSet and the DataSet’s Relation property was used to create parent child relationship between the columns as described above. When the ultratree’s SetDataBinding method was used to bind to the dataset with the parenet child relationships specifiedt nothing what displayed in the ultratree.
 Below is simple example
·         Here is what the table looks like
Column1           Column2           Colum3             Column4
event                sports               baseball            45
event                sports               baseball            93
event                sports   football 1
event                music               classical           33
event                music               classical           44
performace       drugs                steroids            111
performace       drugs                medicine           225
performace       equipment         weight               111
performace       stuff                 pay                   225
performace       stuff                 pay                   275
performace       xyz                   pay                   275
·         The name of the table would be equipment.
·         This table is stored in a DataSet object.
·         The relationship in code was creates using the DataSet obect.
dataSet.Relations.Add("parentone", dataSet.Tables["equipment"].Columns["Column1"], dataSet.Tables["equipment"].Columns["Column2"], false);
dataSet.Relations.Add("parenttwo", dataSet.Tables["equipment"].Columns["Column2"], dataSet.Tables["equipment"].Columns["Column3"], false);
dataSet.Relations.Add("parentthree", dataSet.Tables["equipment"].Columns["Column3"], dataSet.Tables["equipment"].Columns["Column4"], false);
·         The DataSet object was bound to the ultratree with the relationships specified
  ultraTree1.SetDataBinding(dataSet, " Column1. Column2. Column3");
·         When the ultratree was displayed it is blanked.
Any opinions on why nothing is displayed in the ultratree?
  • 53790
    Suggested Answer
    Hello Sfrierdi,
    If I understood your scenario, I think that you are able to create a hierarchical tree using a single DataTable. Could you please take  a look at the attached sample for more details. Please let me know if you think that I misunderstood your scenario or if you have any questions
    Regards
    Georgi
    UltraTreeDataBinding.zip
