We would like to create our column chooser.
And we would like to make drag and drop column from/to our column chooser to grid. - Like it was implemented in Infra column chooser.
How can we make the same drag and drop column?
Maybe we should release some interface?
Thanks.
Okay, that's what I thought. I can't see any way to do this currently. You should Submit a Feature Request.
By Definition, i meant adding a description column in teh column chooser that shows description or each column.
Hi Valliappan,
What do you mean by "definition?"
There's no built-in way to add a column to the column chooser. But it might be possible with some creative coding. The ColumnChooser is actually a WinGrid and you can access the grid control on the dialog, so yo might be able to get this working. It would require a lot of tricky coding, though, to get the grid and add a column to it and then populate that column.
Can we customize windows ultrgrid column chooser for the below feature.
- Add a additional column in the column chooser that shows the definition for each column in the grid?
Valliappan
1) There's no support for this in the current ColumnChooser. I recommend that you Submit a Feature Request. Maybe this can be added in a future release.
2) There's no built-in support for this, either. But it would be pretty easy to implement. When the user changes the visibility of a column, the Before/AfterColPosChanged event will fire. So you could trap AfterColPosChanged for when a column becomes visible and then use grid.ActiveColScrollRegion.ScrollColumnIntoView to scroll that column into view.
