Hi everybody, I decided to post this little sample project to share the way I used to make the UltraExpandableGroupBox resizable.Please feel free to re-use this resizable control in your projects if you find it useful.Bye Gianni
Did you try the example solution I posted?It still works to me. What Infragistics version are you using?What OS is running on your machine?What version of .net Framework are you using?Are you working with Visual Studio? What version?
Could you post a little project that cause the exception you're talking about?
Gianni
i can't make this thing to work, getting a pIvoke error and if i place it inside a flowlayoutpanel. It also throws an error
