800
How to extend middle column instead of the last one?
I have an UltraGrid with 3 columns, and when the grid is resized by the user, I want the 2nd column to fill the expanded space, not the last column.  I tried to do this with the answer at http://blogs.infragistics.com/forums/p/22353/81471.aspx#81471, but it doesn't work, when the grid is resized all columns remain fixed (and yes I've verified in the debugger that the 2nd column isn't getting the min/max width values set).
I'm using 11.1 and the answer I was using was from a couple of years ago.  Is there some different way of doing this in the newer versions, or did I just run into a bug?  If it's a bug, any workarounds I could try?
