370
How to fix the size of series of data in 2d column ultra chart
The graph I got is like followings :for more data its coming ok ,but for less data the bars of the graph is stretching.
Is there any way to fix the size of the bars in the graphs..
Can you also please suggest  to have some space between legends and the graph.
  • 53790
    Hello Manaswini,
    The mentioned behavior (screenshot 2 and 3) is expected if you are using the default settings. Maybe one possible way to change this behavior if you are using the properties:
    ultraChart1.Axis.X.RangeType = Infragistics.UltraChart.Shared.Styles.AxisRangeType.Custom;
    ultraChart1.Axis.X.RangeMin = 0;
    ultraChart1.Axis.X.RangeMax = 10;
    Also you could used these propertis to your Y axis.
    You could used for example the properties:
    ultraChart1.Legend.Location = Infragistics.UltraChart.Shared.Styles.LegendLocation.Right;
    ultraChart1.Legend.Margins.Top = 50;
    Regards
