I have an UltraGrid that I have used the column arranger on. A png of the grid in designer view is attached. There are ten lines of directions that can be displayed. We would like to be able to either set the cell height to zero or something of that nature so if there is only one line of data or a line in the middle is empty, not all of the lines are displayed at runtime so the user does not have a lot of wasted space on the screen. I tried using the hidden property, but it only hides the cell, but leaves the dead space taken. Is what I need to do possible?
Thank you for your feedback. I am glad to hear that you have come up with a solution for your 'issue'.
Please feel free to let me know if a question about our toolset comes up on your mind.
Thanks for researching that. We decided to change back to using the grouping style grid and the backend will send all of the rows of directions data as one text string. We can then get the look we want by setting the text for that cell to wrap and then perform the AutoSize when each row is initialized. That gets us close enough to what we wanted. They when the user double-clicks on the row to edit the data, we will put each row into its own grid row for maintenance purposes. Thanks again for helping and doing the leg-work for us.
Bob
Hello Bob,
After spending some time researching the desired look by you I believe that the 'WinGrid' does not support this kind of functionality by default and this would be a non-intuitive user interface. You might want to consider putting the 'WinGrid' in cardview mode or using another control for this, like 'UltraTree' for example. However another possible approach to achieve your scenario could be using a 'CreationFilter'. You could read about it at the following link: http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/Win_Creation_Filter.html.Here are some topics from our community which could also help you: http://community.infragistics.com/forums/t/34485.aspx, http://forums.infragistics.com/forums/t/47561.aspx http://community.infragistics.com/forums/t/58186.aspx, http://community.infragistics.com/forums/t/9989.aspx and http://community.infragistics.com/forums/t/50234.aspx.
The above approach is not so recommended, because it features element's resizing, creating or removing and could lead to some unexpected behaviors.
Please do not hesitate to ask if something comes up.
Boris,
Attached is my modified version of your sample.
Could you please review the sample attached to this post and see if it meets your requirements. If this project does not reproduce your scenario, please make the needed corrections and send it back to me if it is possible for you.
Please feel free to let me know if I misunderstood you or if you have any other questions.
