Hallo!
I have a set of usercontrols containing dockmanagers to emulate variuos "containers": a userControl emulates a dockPanel, another emulates a splitcontainer, and so on.
I made a simple test application (in attachment) that reproduce my problem.
At startup the application looks like this:
Then, the user resizes the window, for example maximizing it, then it clicks on the second tab.
The content of the second tab is displayed:
The problem is that, on the right pane, the panes labelled "Chart", "Selected point" and "Quick watch" are not displayed in the proper aspect ratios, by default. In this example, the "Chart" pane is supposed to be larger.
The correct default aspect ratio is displayed if the user resizes the vertical panel between "Properties" and "GridChartControlContainer"
I would like to have a chance to make the content of the "GridChartControlContainer" to authomatically size at the proper aspect ratio without the need of user interaction.
If it could help to solve the issue, it used to work until we switched from version 8 to version 11 of Infragistrics' components.
Thanks!
Hi all,
This issue has been resolved in the latest service release for NetAdvantage 11.2, (build 2074) as well as the version 12.1 of our product.
If there are any further questions regarding this release, please let me know.
Sincerely,Chris KDeveloper Support EngineerInfragistics, Inc.www.infragistics.com/support
For those interested, this issue is currently under going testing, (Dev. Issue ID 99282). I will be updating this thread once the issue is pending for release.
If there are any questions in the meantime, regarding this development issue, please let me know.
