690
Space Key on a grid
Hi, I've a grid witch is binded with a datasource. I've a boolean column witch is checked when the user press space key. To do that, I use the grid.selected.Rows.
When I press space on a multiple selection, the activeRow is in the grid.seleted.Rows
and When I Press the space key another time, the activeRow isn't selected and isn't in grid.seleted.Rows
Because of that, when I check the boolean column, I've to test if the activeRow is selected or not to not forgive it :
If I don't modify the boolean column (the grid doesn't enter in edit mode), the grid reacts in the same way.
Could I know why the componant react like that ?
