Hi I am trying to change the checkbox graphic using the code below..
Dim img2 As Image If CBool(e.Row.Cells("Principal").Value) Then img2 = imlApplication.Images("Power On.png") Else img2 = imlApplication.Images("Power Off.png") End If e.Row.Cells("Principal").Appearance.Image = img2However when tested both the original checkbox and img image show in the cell. How do I remove the checkbox image?Thanks
The easiest way to do this would be to use the CheckBoxGlyphInfo or an UltraCheckEditor in Custom style.
But which one you use depends on what you want.
Do you want to do this for your whole application, or the whole grid, or just one column in the grid?
