Could you point to any online example to use Infragistics.Documents for PDF ?
Thanks ..
i am just curious is it the same way to creat pdf vb.net with other documents. can i use the same method. if so,that would be good to learn one way.
Not now.. Probablly latter when I start project. From your links I found decent examples "for start" ..
Hi dmcmichael,
Please let me know if you need further assistance with this matter.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
Apologies for the previous misconception.
Our 11.1 documentation still has information on the Infragistics.Documents library:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=DocumentEngine_Writing_Reports.html
In your scenario you may find useful information in the following resources for adding a table/grid to a report:
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2011.1/CLR4.0/html/DocumentEngine_Tables.html
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2011.1/CLR4.0/html/DocumentEngine_Grids.html
As per using the UltraWebGrid in your implementation, UltraWebGrid may be bound to hierarchical XML as described at:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=WebGrid_Binding_WebGrid_to_an_XML_Data_Source.html
If you wish to attach a file to your post, you can add it through the Options tab on the reply page.
Please feel free to contact me with any questions.
