Hi ,
Can someone provide me the link which shows how to implement Load on demand for wingrid.
I came to know that Wingrid doesn't support paging and I want to implement this as I have million of rows in the grid.
As this is urgent can someone quickly refer to the link.
I made a search in the knowledge base and couldn't found it. There is one example for Webgrid which is for hierrachical grid
thanks in advance.
Thank you Gianni!
Your post helped me find the sample right away after I spent time looking through the samples without success.
Hi everybody,
to call it "one million rows example" could be just a little bit misleading because it is called "virtual Mode" on the samples list.
Go on Start Menu -> Programs -> Infragistics, then the Infragistics version you have (e.g. NetAdvantage 2009.2), then Windows Forms -> Samples -> Samples (Local) Once you clicked on "Samples (Local)" a menu application will start. Navigate to "Grid" section, then in the "WinDataSource" group you will find a sample called "Virtual Mode": that's the "one million sample".
byeGianni
There's a million rows sample installed with NetAdvantage.
