1995
Find in combo
Mike,
I am using IG 2011 v2 Service release 2004. In my application to find the value exists in the combo and to get the display text of given key value, i am using "GetText".
Last week i faced one problem. If i gave a value in uppercase and the original value is in propercase in combo, the result of GetText is coming as Nothing. Whether the GetText is case sensitive?
Example :
My combo contains UOM with uomcode as first column and description as second column.
UomCode     -  Description
Lt                       Litre
Kg                     Kilogram
Mt                     Meters
Gr                    Gram
Scenario 1 :
I call the gettext as below
Dim lnIndex as integer = -1
dim lsDisplaytext as string = ""
lsDisplaytext = Combo.Valuelist.GetText("Kg",lnIndex)
The result is coming as "Kilogram" for lsDisplaytext and 1 in lnIndex
Scenario 2:
If i call as below
lsDisplaytext = Combo.Valuelist.GetText("KG",lnIndex)
The result is coming as Nothing for lsDisplaytext and -1 in lnIndex.
Whether the key value should be case sensitive? Guide me.
  • 469350
    Clearly the GetText method is case sensitive. Since it's matching a DataValue, it needs an exact match, regardless of the data type of the value.
