2430
Getting a Key not found error on (breakdownGrid.DataSource = src;)
Below is source code:  but not certain why I am getting a Key not found - tried Binding at Runtime to datasource without any schema defined.  Also defined schema and no use.
UltraDataSource src = new UltraDataSource();
src.Band.Columns.Add(
"Phase");
"Unit Code");
"Unit Description");
"Maintainable Items", Type.GetType("System.Nullable`1[System.Int32]"));
"Technology Type Assigned", Type.GetType("System.Nullable`1[System.Int32]"));
"Size Assigned", Type.GetType("System.Nullable`1[System.Int32]"));
"Service Assigned", Type.GetType("System.Nullable`1[System.Int32]"));
"FMECA Assigned", Type.GetType("System.Nullable`1[System.Int32]"));
while(reader.Read())
string sPhase = reader[0].ToString();
string sUnitCode = reader[1].ToString();
string sUnitDesc = reader[2].ToString();
int iTotal = reader.GetInt32(3);
int iTTTotal = reader.GetInt32(4);
int iSizeTotal = reader.GetInt32(5);
int iServiceTotal = reader.GetInt32(6);
int iFMECATotal = reader.GetInt32(7);
object[] values = { sPhase, sUnitCode, sUnitDesc, iTotal, iTTTotal, iSizeTotal, iServiceTotal, iFMECATotal };
src.Band.DataSource.Rows.Add(values);
reader.Close();
  • 71886
    Hello haessd,
    I tried this and it always works fine for me so I attached my sample to this post for you. Please review it and feel free to let me know if I misunderstood you or if you have any other questions.
    DataSourceSchemaGrid.zip
  • 1210
    Any chance you have code in some events for the grid (e.g. InitializeLayout or InitializeRow)? Maybe you are referring to a column using wrong name in one of those events?
    Just a thought... I am not seeing anything wrong in the code you posted.
    Trausti
