Dear all,
I have below issue. Do you know how to solve it?
public void RefreshList(){dt = new DS_LoyaltyClearPoints.DTLoyaltyClearPointsDataTable();DS_Loyalty.DTLoyaltyRow dr = dt.NewDTLoyaltyRow();
.......................dr.ExpiryDate = temp.MembershipProfile.enddate; // dr.ExpiryDate is DateTime Value...........................
this.ultraGrid1.DataSource = dt;
DateTime last_expiry_date = Convert.ToDateTime(this.ultraGrid1.Rows[i].Cells["ExpiryDate"].Value); // Prompt error in object not set to reference...
Where does the code that causes the error get called from? What event is this code in?
If you are getting a NullReferenceException, then something in that line of code is null. So check those objects and see which one is coming back null. It is the row? Te cell? The Value?
