Hello friends, I have an System that have references from Sheridan and Infragistics, Now I'm installing Sheridan 3.12 but don't recognized the license and I obtain the same result when I install Infragistics 2004 vol. 3, The installer say: CD Key invalid, would you like install as Trial? but I have the correct keys, I've tried in other PC and all is installed without problem.
Please help, what must I do,
PC: Windows 7 64 bits.
Please, regards
Hello, thanks for replying, My scenario is this, I'm installing in a machine in mode Remote, I can't Restart, I have done this: I've installed the product in a Machine with Windows XP before I export the regedit key, I my machine with Windows 7 I have imported the keys, previosly I've installed all controls but only the dlls in Windows 7.
Now all is ok.
Regards.
The invalid CD-Key issue sounds like what is described in KB01979. Rebooting the machine may help resolve this. Since you're on a machine with UAC functionality, you may also want to try running the install from an Administrator command prompt (run cmd.exe as an Administrator) so that the installer is run with elevated permissions from the start.
